profdant139
Apr 05, 2022Explorer II
BFL, that is valuable info! The battery was full when I did this test, so that may explain why the voltage drop was so slight.
I should deplete the battery to a 50 percent state of charge (around 12.1 volts) and then re-try my side by side comparison of the two cables. I suspect that the drop will be more than two percent.
And LittleBill, that's a good idea, but the controller is built in to the portable panel and can't be removed.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
