BFL13
Apr 06, 2022Explorer II
It is PWM. All Vdrop does is make the controller hold the high set point at a lower V but by the time the batt gets to a high SOC the amps have tapered
Also amps are lower later in the day when the batt gets full with the 120W only doing about 7 amps at high noon
The 13.8 vs 13.5 is a difference not the Vdrop for each wire at pick a number amps
OP needs an hydrometer. His batt could be sulfated with those 13 .x voltages
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
