jconnally
Feb 22, 2014Explorer
Perhaps a bad converter and thus not charging the battery causing a dead battery?
Disconnecting the battery and still having the problem eliminates the battery charging from overloading the converter. Really sounds like a bad converter now. Since you have a dead battery and the converter will not run due to tripping the breaker, put a charger on the battery and see if the voltage will come up. Leave the charger attached and it should provide 12V until you replace the converter.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
