campigloo
Mar 02, 2014Explorer
Thanks to all of you who tried to help with my problem; even those with a bad attitude. Turns out, after I thought about it and found the problem was in the receptacle circuit, I decided to look at what moves. The problem was in the block connector that went from the hard wire to the flex wire for the receptacle in the slide. Cut it out, added a couple of wire nuts and presto!, juice again! Thanks!!!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
