grizzzman wrote:
I think what is getting lost is the question that MEX answered.
Top charging (conditioning the new battery) This will assist in curing
the plates. Charge to 15 volts (half the volts for a 6 volt battery) then termanate the charge. You can float if ya want after.
So the idea is to get the battery voltage to 15. I was getting this confused with setting the charger to 15 and let it do Bulk and Absorption.
If you do that, then Bulk will end at some SOC depending on the charging amps wrt bank AH size. Might be at 75% SOC or less or more. Battery voltage will not yet be as high as charger set voltage. That will only happen at the end, when the battery is full.
