I have a 92 p30 chassis motorhome.I have the four headlight system.Two on the outer for dim and two on the inner for bright.I know there is a way to make all four to come on when on bright but dont kn...
Rewire the low beam wires to the common connection on your high/low switch. In this way the low beams will be on all the time, and only the high beams go on or off.
