I have a 92 p30 chassis motorhome.I have the four headlight system.Two on the outer for dim and two on the inner for bright.I know there is a way to make all four to come on when on bright but dont kn...
As landyacht said. Proper voltage first then as cpaulsen said install a relay kit to run more current through a relay and not run both beams on your switch. Sometimes the switch or connector on the back of it will melt.
