I have a 92 p30 chassis motorhome.I have the four headlight system.Two on the outer for dim and two on the inner for bright.I know there is a way to make all four to come on when on bright but dont kn...
Make certain your lamps are a minimum height from the ground. I've dealt with BLUNDER motorhomes in the 90's with lamps low to the ground and 1,000 watts of light at that height wouldn't have helped much. I just helped install a 140 watt short LED light bar atop a motorhome here, that is aimed 150 feet ahead of the vehicle. High beam controlled.
