joe0508
May 21, 2014Explorer
bright lights
I have a 92 p30 chassis motorhome.I have the four headlight system.Two on the outer for dim and two on the inner for bright.I know there is a way to make all four to come on when on bright but dont kn...
joe0508 wrote:Does this look like something that will work in my situation?http://www.ronfrancis.com/prodinfo.asp?number=HR-58rjxj wrote:Can i get a relay kit for sealed halogen headlights with two prongs?
As landyacht said. Proper voltage first then as cpaulsen said install a relay kit to run more current through a relay and not run both beams on your switch. Sometimes the switch or connector on the back of it will melt.
