joe0508's avatar
joe0508
bright lights
I have a 92 p30 chassis motorhome.I have the four headlight system.Two on the outer for dim and two on the inner for bright.I know there is a way to make all four to come on when on bright but dont know how to make it happen.Can someone help me out here and tell me how to do it?I would really appriciate it,Thanks.
  • He, wife, dog and two cats headed back to Sn Miguel de Allende. The tough part was the base mounting. He purchased a pair of 5" cube blocks of ironwood. Palo Fiero. Used a rasp to contour the bottom to the roof. Drilled a pair of 3/4" holes. He borrowed my NutSert tool and a to 3/8" X 24 stainless nutserts for the roof. Scratched the fiberglass and drilled 1/8" holes for a place to grab the GOOP and he drilled a few dozen very shallow 1/8" pilot holes in the blocks and left the surface roughened with a grinder disc. Control switch to defeat high beam operation.
  • Here is a link to something that looks exactly the same. I did not purchase it. He did. I fed it with red and black 12 gauge cross link XL wire, and a 20-ampere ATO fuse.
    http://www.ebay.com/itm/30-Light-bar-140w-LED-Cree-spot-off-road-race-driving-4x4-SUV-roof-bar-UTV-ATV-/281090452652?pt=Motors_Car_Truck_Parts_Accessories&hash=item41724becac&vxp=mtr
  • Pau Ferro is unbelievably beautiful wood. Harder, Denser than Red Oak
    http://www.wood-database.com/lumber-identification/hardwoods/pau-ferro/
    I however developed a sensitivity to it after a belt sander was shooting the dust into my belly button.
    Pretty Oily. Oil based Minwax polyurethane would not cure on top of it. Had to use water based Poly.
    I had no issues with titebond2 adhering to it, but others report gluing failure. I guess it depends on exactly how Oily any particular Piece of wood is.
