today I went to the TT and decided to bring in the slides this year for the winter. My TT is plugged into a 30 amp service and I have one button to bring in both slides. the bedroom comes in first the...
I think you mean the converter fan is coming on, after holding the button. This is likely due to over taxing of converter, which cannot handle the larger slide operation on it's own. Battery needs to be checked/tested. With a strong battery, you should be able to operate slide, without shore power.
You could test system with a known good battery, such as jumping direct from your tow vehicle battery, to see if slide operates correctly.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
