today I went to the TT and decided to bring in the slides this year for the winter. My TT is plugged into a 30 amp service and I have one button to bring in both slides. the bedroom comes in first the...
Check the battery and the terminals to make sure they are clean. If the battery is fully charged, and the terminal clean, check to see if there is a ground cable. Years ago when I owned a Sunline trailer, I had trouble with a slide not wanting to operate. When I looked under the slide, there was a ground cable going to the frame. I removed the bolt, cleaned the connections and the slide worked.
It might help if you provided more info on what trailer brand, slide mechanism, etc.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
