old_guy
Nov 20, 2018Explorer
bring slides in
today I went to the TT and decided to bring in the slides this year for the winter. My TT is plugged into a 30 amp service and I have one button to bring in both slides. the bedroom comes in first the...
old guy wrote:MFL wrote:
I think you mean the converter fan is coming on, after holding the button. This is likely due to over taxing of converter, which cannot handle the larger slide operation on it's own. Battery needs to be checked/tested. With a strong battery, you should be able to operate slide, without shore power.
You could test system with a known good battery, such as jumping direct from your tow vehicle battery, to see if slide operates correctly.
Jerry
not so Jerry. it is the fan in the overhead vent that comes one for a few seconds
