joshuajim wrote:
dougrainer wrote:
Your Welcome:B Doug (NIASE certified and MASTER CERTIFIED RV TECH)
Remember, your record is good because you went for help.
PS. The MOST common cause of your problem is NOT torquing the mount bolts correctly, not that they installed the impellor wrong
Did you read the part about being an ASE mechanic. The bolts were torqued to 45 inch pounds. I still have over $10,000 worth of tools. Probably almost as many as you have. :)
It is a good thing you fixed it. If you had taken to a Dometic service center, odds are they would have charged you for the repair. I have repaired/replaced upwards of a Thousand AC units, and NEVER had one that the Impellor was rubbing by Manufacturer (appliance)build mistake. Always install error. FYI, due to insurance purposes, My Boxes and Tools total over $34k. 41 years as an RV Mechanic kind of adds up in tools. Doug
