kalia
Jul 15, 2018Explorer
Dometic Brisk Air air conditioner
First off, my apologies for posting in the wrong place. Here's my post again. Our Dometic Brisk Air air conditioners (13500 just like the one pictured by RobWNY 7/18 along with the thermostat and the other 15000 with the same type of thermostat) turn on and off sporadically & have been doing such for 2 months. These are in our 2018 Jayco Bungelow. Our repair person has called Dometic numerous times and gets a different answer every time. I've even tried calling them and after going through all the details have been told I can't speak with a tech because I don't have an account with them. Fan will shut off for a few seconds, something hums loudly, then fan turns back on. Fan will go from "low" to "low", then "high", then "high", then "high", then "low", etc. This happens no matter what the outdoor temp is. In fact, the 15000 did it one night when the outdoor temp was lower than the indoor by a couple of degrees. I timed the 13500 one night for an hour while in bed. It shut down for approx. 45 seconds, hummed, then turned back on for 2 minutes then repeated. 15000 would do the same thing. Now both are turning off and on in a much shorter time span...1 min. on, 5 seconds off, hum, repeat. We had the fan set on "auto". Thermostat for the 15000 has been changed out...no difference. 13500 has a new electric component box inside...no difference. We're a little edgy sleeping at night and also don't want to go away during the day for a few hours leaving the dog in the unit for fear of a fire. Any suggestions will be deeply appreciated. Thank you all in advance. And I'm going to add... each and every one of you was a rookie at posting at one point in time and I thank those who have offered their sincere help.
