Gjac
Jan 29, 2021Explorer III
I fixed mine with a steel pipe I had laying around. I slid the steel pipe inside the the broken Al tubes drilled two holes one in each section through the tube and steel pipe then installed SS bolts and nuts. I made an outer sleeve from another section of a broken tubing just to cover the split section. The repair cost nothing but about 2 hrs of my time and is much stronger than the original 3/32 in Al tube. That ladder is an easy target for trees, gutters and large boulders especially if you are backing up alone.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
