Gdetrailer
Jan 29, 2021Explorer III
Ramblin' Ralph wrote:
Thanks for your comments. I agree that internal tubing would be the best fix. I also agree a new ladder is not that much. However, finding an exact replacement has not been easy. If I could find one, it would mean drilling no new holes and make the job much easier. I'll probably go with a new “universal” ladder and hope it's not too hard to modify and install for my application.
Exact replacements may not be a choice since most RV manufacturers typically will have most items custom made for their setups.
Aftermarket replacement ladders typically will be adjustable to a certain extent. If things workout the ladder mounts may be adjustable which would reduce the need to add new screw holes..
One must also ask the question, How many times do I need to access the roof?
Once a yr?
Twice a yr?
Once every couple of yrs?
Every trip?
Myself, once a yr max and that is just to check the roofing and caulking.. 8ft step ladder setup beside my TT once a yr does the trick for myself so I never felt the need for a built on ladder..
Besides, I have used those built in ladders for my Dads 5ver to help him find a leak.. Sketchy at best, rungs not predictable placement since his rear wall was not straight.. Had to watch your step closely..
