samsontdog's avatar
samsontdog
Broken rear window
I was replacing the struts on my rear window on the hinged door that raises up on my canapy,or some people call it camper shell that sits over my p/up bed. The glass shattered into a million pieces. How did anyone who had this problem get it replaced? Glass Companys will not touch it, RV Places will not replace. So what do I do? My DW said "just buy another shell"
I told her the shell I bought in 2000 cost $1,100 and they have doubled in price. One Company said they would replace the door and cost would be $621.00 total
  • When my truck cap suffered vandalism an auto glass repair shop fixed me up, no problem. Even replaced the original clear glass with tinted.
  • Bill.Satellite wrote:
    So, if you can get a replacement in 8 weeks you are in business!
    Not really as we leave for 3 months in 3 weeks
  • I just figured you could seal it up with something until then. Sounds like others have had success with auto glass shops, however.
    Are you in Arizona? If so, check these guys out:
    Clicky
  • I broke the rear window in my truck cap - local glass company replaced it no issue. Not sure why they won't for you...
  • Wrecking Yard
    Pickup Truck rear glass of cab. Use glass cutter to fit. Same type of safety glass.
  • It is flat glass in an aluminum frame or a molded frame-less piece of glass?
  • The local glass company replaced mine with Polycarbon (plastic). I think is was $20.00.
  • MEXICOWANDERER wrote:
    Wrecking Yard
    Do NOT attempt to cut temper glass.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
