- MEXICOWANDERERExplorerMore curious...
An unvented 10,000 BTU heater is said to generate heat 132% as long on a gallon of kerosene rather than propane. - bfast54ExplorerBUT...The HYDROGEN, in H2O.......is combusted ..so, there is that....:W
- kellertx5erExplorer
JaxDad wrote:
kellertx5er wrote:
MEXICOWANDERER wrote:
Since LPG has a weight per cubic foot density similar to diesel it would make sense that BTU specs would be the same. However substituting LPG as a motor fuel reveals a drastic sum difference in economy. This is curious.
Water has 20% greater density than diesel, but I have yet to find a way to burn it!
They’ve been doing it since the 1800’s.
Google “oxyhydrogen generator”.
Wiki entry for Oxyhydrogen
A Canadian company developed a process a few years back where they added a device to transport trucks that converted distilled water into Oxyhydrogen and injected it into the engine when the turbo came on as a power booster of sorts. It works quite well, far better overall than propane injection.
This process involves the combustion of hydrogen and oxygen gasses. I was speaking of the LIQUID known as 'water'. - JaxDadExplorer III
A Canadian company developed a process a few years back where they added a device to transport trucks that converted distilled water into Oxyhydrogen and injected it into the engine when the turbo came on as a power booster of sorts. It works quite well, far better overall than propane injection. - kellertx5erExplorer
Water has 20% greater density than diesel, but I have yet to find a way to burn it! - MrWizardModeratori was thinking something similar
engine operation, depends on flame propagation and the pressure created in the combustion chamber, to drive the piston down - JaxDadExplorer III
Simple science actually, propane makes the same(ish) heat as diesel but it doesn't explode as fast as vapourized diesel, especially under pressure, so it takes a lot more propane to accomplish the same work.
Thus when burning it slowly (compared to an ICE) you get similar heat, because the losses are mostly eliminated. - MEXICOWANDERERExplorerSince LPG has a weight per cubic foot density similar to diesel it would make sense that BTU specs would be the same. However substituting LPG as a motor fuel reveals a drastic sum difference in economy. This is curious.
- DrewEExplorer IISince they're both hydrocarbons, I guess it rather makes sense that per pound they have similar energy content.
Per gallon, USLD has about 50% greater energy density (and ordinary mass density). - MEXICOWANDERERExplorerI need to do more research :)
Kerosun 10,000 BTU heater says one gallon lasts 10-12 hours. A 10,000 BTU LPG heater would therefore last 8 hours or so with a gallon of LPG?
A gallon of ULSD costs $3.90 down here. LPG is about $2.50 gallon but a lot more inconvenient.
Maybe a larger tank? Sure goes not seem to be a lot of difference in energy per gallon or per lb.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
