scottandgaye
May 06, 2021Explorer
This is what I use. It shows a high and low temp, along with the current temp of both the freezer and the refrigerator. I have the display mounted on the outside (side) of the fridge using heavy duty Velcro and it hasn't come off yet due to heat. I find that I check it regularly each day, just to make sure that everything is working as it should. The high/low temps are resettable and it has an alarm function if the temps are out of range.
Scott
AcuRite Refrigerator Sensor from Amazon
Scott
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
