Edd505
May 06, 2021Explorer
scottandgaye wrote:
This is what I use. It shows a high and low temp, along with the current temp of both the freezer and the refrigerator. I have the display mounted on the outside (side) of the fridge using heavy duty Velcro and it hasn't come off yet due to heat. I find that I check it regularly each day, just to make sure that everything is working as it should. The high/low temps are resettable and it has an alarm function if the temps are out of range.
Scott
AcuRite Refrigerator Sensor from Amazon
These don't work worth a ****. I have one and it is at least 10 degrees off and no way to calibrate. I bought two small analog thermometers for home refrigerators and hung one in each compartment.
Thermometer
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
