Reisender
Dec 31, 2020Nomad
BFL13 wrote:
How long do you need to run how big of a load before you recharge the battery?
How much time do you have to recharge the battery before you need to use it again?
So the answer is, it varies. As low as 45 watts and as high as 225 watts. So does the duration it has to stay on. I think my blue top is around 38 amp hours. I would like to add a little extra capacity so 50 - 55 amp hours would work. I’m comfortable with AGM’s but I know Lithium have kind of become mainstream and they are soooo much lighter. And once we get into lithium all my past knowledge of chargers go’s out the window.
Heads up. I have the inverter picked out. 700 sine wave Gopower.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
