JaxDad
Nov 27, 2019Explorer III
pnichols wrote:JaxDad wrote:pnichols wrote:JaxDad wrote:Johno02 wrote:
Like someone else said, Google, or a cell phone is great, IF you have cell or internet service. If not, it is just a useless hunk of junk.
Not true at all..
Several GPS apps (for both iOS and Android devices) allow you to download the map database (in whole or just the part you need, in detail or not) and then your phone or tablet will work regardless of service availability, even in airplane mode.
I use an iPad mini (8” screen) with a Bad Elf GPS dongle and end up with a GPS that I can also check in on RV.net with after I get there.
Try that with your Garmin. LOL.
Hmmm .... what exactly do you mean by "I can also check in on RV.net with"? You need Internet access to do that after you get to where you were going. (Some of our destinations don't end up where there is Internet access.)
Also, I wonder how many smartphones have enough built-in memory so as to hold at all times the entire map database for North America ... like our 3550LM stand-alone Garmin unit can. We can travel anywhere in the lower U.S. or Canada or Alaska (or Mexico) without having to download any regional maps -> the huge map database for all of this is right there in the Garmin, which came with lifetime free map updates - which makes it a no-brainer to keep current. This makes for one less thing to have to remember to take care of/prepare before a major RV trip.
P.S. A Garmin stand-alone unit will only lead you on a Wild Goose Chase if you let it do so. :)
The comment I was replying to was that a phone wouldn’t work if you had no cell service. By tethering my iPad to my iPhone there’s very few places I don’t have Internet since I can access almost every carrier and just choose the strongest signal where I happen to be.
As for storage, the entire map database for all of North America is on ~2.36 GB and you have the option of loading just the portion you need in which case it’s only a few hundred MB. Even the smallest of smartphones are 16 GB and 64 GB is pretty standard these days, some even 128 or 256 GB.
I guess there's something I'm missing in what you're saying:
We tether our iPad to our smartphone when on RV trips too ... since our iPad is not set up as an independent Internet device. However, our smartphone operates on the Verizon network ... and only that network because that's who we signed up with years ago.
So here's my question - how can your iPhone "access almost every carrier"? How do these various carrier's bill you for your iPhone use on each of them, if you jump around on them as you please in any given time period? (I thought a smartphone was registered with, and the owner billed by, only one specific carrier that the owner's device is registered with.)
Of course if a smartphone has a complete mapbase installed locally on it, and the smartphone can function as a satellete based GPS receiver independent of an Internet connection, then I guess that the right smartphone containing the right mapbase can be setup to look, act, and function like a standalone satellite based GPS navigator device.
If so, the above point is not well made in most of the discussions comparing the two approaches to RV navigation aides. Also if so, I should probably retire my Garmin 3550LM and use a smartphone instead, for navigation help whenever we're RV traveling out in the boonies beyond cellular signal reception.
Quotes of quotes this long make me a little crazy, but here goes.
Stand-alone is the key. A phone or tablet running without cell service is no different than a stand-alone GPS for navigating, but is a LOT more useful for other things beyond navigation.
The trick to ‘any network’ is the company that provides your service. Verizon isn’t going to tell you they have sharing agreements with a bunch of other companies. They want to keep your money. No surprise, your Ford owner’s manual says all sorts of terrible things will happen if you don’t use ‘genuine’ Ford parts. There are however other providers that have made those agreements.
My cell phone is ‘local’ (no roaming, no long distance) in most of the world, I can switch between several phone numbers in a couple of key strokes, or switch between most cell providers automatically or manually, again with a few key strokes.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
