NinerBikes wrote:
Hooking up a 24 V panel, capable of 30V with no regulator, diretly to a 12V battery, should be enough info. Someone tries this on an expensive AGM or Surret or Rolls battery, because they read it here, and they're not going to be happy with the results or the replacement cost. And any other electrical equipment that gets roasted along the way.
This quote?
red31 wrote:
I thought ya could connect a 24v panel directly to a 12v battery, disconnect when battery voltage is desirable.
I think you are taking it out of context.
Not really a question, recommendation or reflecting actual experience.
Statement does not even stand on it's own as several previous posts are needed for perspective.
BTW, what harm is done if disconnected at 14.5 volts on the battery?
