Caryite
Oct 19, 2015Explorer
burned wires in converter. Fix wires or replace converter?
Hi,
The converter in my TT is not working and I've used a multimeter to confirm that my shore power is providing 120 VAC. It is a 30 amp system.
It appears the burned and corroded wires are the problem from this picture below:
Is it worth cutting off the burned/corroded portion of the wires and then reattaching them to the neutral terminal bar, or does it appear the neutral terminal bar needs to be replaced as well? I was going to try to address the wires first inside of the WF-8944PEC converter (3 years old) before attempting to replace the entire converter.
Any suggestions would be appreciated. I don't plan to work on this until next weekend.
