davidkingham
Mar 09, 2023Explorer
It's a Suburban 2390 SF-25FQ, the trailer is a 2016. I have never smelled it outside, but I'll double check the next time I smell it inside. It is not coming out of the vents, only directly around the furnace, which is below the range/oven. The furnace works well otherwise. With a previous thermostat it was turning off before reaching the set temp, and I would have to cycle it to get it to come back on. But I don't think that has happened since putting in the Micro-Air EasyTouch RV thermostat. Blower works fine, no weird sounds. I have noticed the temp of heated air doesn't seem as warm as it used to be. I've fully inspected all the wires and have found zero signs of burning or melting. Thanks for the help Chum!
