30sweeds
Mar 11, 2023Explorer
Ozone and burn smells are 2 different things. Ozone is created by arcing or sparks,burn is...burn, as in wire insulation.Since you have seemingly checked everything on the furnace,just for kicks,check the shore power breakers for loose,corroded,burnt connections.If you were ever in a low voltage situation,that stuff gets hot and compromises the breakers and connections without tripping the breakers.
