SconesyCider's avatar
SconesyCider
Burning smell from electrical panel
So here is the skinny;
Travel trailer is hooked up to shore power. Battery disconnected. The furnace and television were on one day when I noticed an electrical smell from the panel. Noticed it’s from the 12v fuse board. The negative lead is warm to the touch, soldering points for negative are blackened. Negative screw terminal has some wiggle to it.
I’ve noticed that the lights have been intermittently dim with a light flicker from time to time. This is accompanied by a light “whine” from the 12v fuse board. Once I turn on an additional switch, the trouble goes away. My furnace fan has given me trouble in the past year. It’s a little louder and blows with less force.
Where should I start?
  • I thought the battery might play a part. I disconnected it upon advice that it would drain the electro lights while hooked up to shore.
    I picked up an exact replacement 12v fuse panel for my Paralax 7300 series electrical panel today.
    Reconnecting battery now.
    Come to think of it, I had the issue of lights flickering(not dimming) and a lie whine/buzz prior to taking the battery off.
  • newman fulltimer wrote:
    Your converter is frying itself with no battery hooked up
    I agree it should have a battery hooked up. It also sounds as if you are describing a loose solder connection on your terminal. And that will cause heat and a poor connection. If true, you need to get an electrical tech to repair it before it gets worse or starts a fire.
  • Burnt areas probably have a loose connection. Replace the burned components and tighten/inspect the rest.
    Otherwise what is the make and model of the panel? Might be best to replace the entire unit.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
