BB_TX
Nov 24, 2020Nomad
BeeBee wrote:
QCMan - thanks for that comment. It had not crossed my mind as a possible cause. Think I will pull and the wires, clean them, and reattach to the block. Might avert a future problem.
Not only the neutral wires but all the wiring in your load center, hot, neutral, ground, and also all the wire terminations on the 12 volt fuse panel.
Something that should be done on new RVs and periodically on older ones. Many of my wires were not properly tightened when new. A not uncommon problem.
