CharlesinGA
Nov 26, 2020Explorer
BeeBee wrote:
Thanks all for the replies. Is an "ATS" the "transfer switch" ? Is that the switch that switches from DC to AC? Where might I find that in my travel trailer?
Read thru the thread and saw that no one ever answered this. The ATS is a switch that allows shore power 120v to your panel and then when an onboard generator is started, it shuts the shore power off and allows the generator power to take over.
The ATS has NOTHING to do with DC 12v power.
If you have a motorhome with a generator you might have an ATS or you might simply have an outlet for the generator that you roll up the shore cord in its compartment and plug it into the generator outlet (manual transfer switch of sorts).
If you have a trailer and no onboard generator you won't have a ATS. If you have a built in generator you might or might not have an ATS or the outlet and plug setup I described above.
Charles
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
