RJsfishin's avatar
RJsfishin
Buy American !!
The good lord knows I tried !
  • Some perdy good posts so far !:)
    Up till a couple yrs ago, I just thought VA was made in the US, as they dint seem to be all that bad of quality. But at that time when I bought a 3/4" bit that wouldn't drill butter because it had been sharpened backwards, is when I read the print on the back. Sad part is, after returning it, I went to Oregon Tool and bought a hi quality USA for 2 bucks less.
    But, this is the first time I had this happen ! It started drilling fine, then all at once it just fell into a 90 deg, could not believe it !
    I doubt this is typical of VA, as I have used hundreds of these small bits. But it sure needs some better quality control for sure.
  • its designed soyou wont go through your siding from the inside its called a inside out zip bit as seen on tv
  • Put it in your electric drill and use for a paint mixer. Paint mixers are shaped exactly the same way! Hey, pretty smart them foreign manufacturers ... 2 for the price of one: Stage 1 it's a drill bit, Stage 2 it's a paint mixer. Actually that's pretty good technology there!
  • So what's the problem? Keep it in your tool box for the next time you need to drill something around the corner.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
