John_Joey
Apr 09, 2016Explorer
Unless you just have to have it, I would walk away. Vehicles want to be driven. When you do they lube up all the moving parts and seals. Just like a body if it sits for too long will slowly degrade. Running an engine will also create heat which gets rid of any water from condensation.
If there is any water in the oil, you could spin out a main rod bearing. If the rings are rusted in the cylinders, then upon initial startup you could score the cylinder walls. All of that will give you problems after the purchase.
If you have to have it, then I would do a little more research on how to start a vehicle that has sat for awhile. Some will spin the oil pump prior to starting the engine, others will drain all the gas, while others will pull the spark plugs and insert oil and let soak for a few days.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
