vermilye's avatar
vermilye
Bypass / Blocking Diodes
Here is the situation: I have 2 roof top panels (95W GoPower, Imp 5.53, Vmp 17.2) mono and a 100W Windy City (Imp 5.75, Vmp 17.4) poly panel wired in parallel on the roof. No room for more.
For low angle winter sun, I add a portable (2 80W panels in parallel) 160W Solar Blvd (Imp 8.88, Vmp 18) mono panel, bypassing the controller. All go to the input of a GoPower PWM controller in the trailer.
All panels have bypass diodes, none have blocking diodes.
Everything works as expected until the the controller switches to float while still under full sun at which point the controller output drops to under .5 amps going to the batteries (a pair of Interstate 6V). At that point unplugging the portable panel INCREASES the output current of the controller from around .5 amps to a couple of amps. Just before sunset, replugging the portable panel will slightly increase the controller's output.
If I connect the portable panel using its controller to the trailer batteries (bypassing the GoPower controller) the same thing happens.
Would the higher Vmp of the portable panel cause this? Would blocking diodes help? (Installing them on the rooftop panels would be a major job - easy for the portable.) Since the panels are not in series, do the bypass diodes serve any function?
Any suggestions would be appreciated. It isn't a major problem, but one that I'd like to understand.
    Maybe..your Vmps are not that different. But in parallel, the closer your voltages are the better.
    Afraid I'm not qualified to comment much more.
  • Remember the little old lady in the WENDY'S hamburgers ads?
    In this case it's...
    "Where's The Volts?"
    Speaking of one without the other is a perfect example of useless information. :)
    And I would say that is exactly as expected too.
    What exactly leads you to believe that there IS a problem ??
    Switching to float implies that the batteries are "full" and don't need the extra current.
