RVServiceManage
Jan 30, 2015Explorer
Jerry,
I would start by checking the condition of you house batteries. Make sure the cells are full of water and have them load tested. The symptoms you describe are related to your 12v side of the coach. If the battery/batteries are good then I would replace the battery disconnect solenoid. This would be the only other item that could intermittently shut off you 12v on it's own.
