brulaz's avatar
brulaz
Cable Lugs or 1/0 cable
Originally setup to just run a small coffee grinder, we're now trying to pull 70ADC from the batteries to run an induction hotplate.
For some reason, these things always seem to get out of hand ... :R
Anyway it's time to upgrade the cables to and from the 1000W inverter. (And maybe later a 2000W inverter will happen.)
Was thinking about 1/0 cable, about 8-12' depending upon routing.
The old cables used simple tinned copper lugs with a V-crimp made with a "Heavy-Duty Hammer Crimper" from Del-City. And lots of electrical anti-corrosion paste, also from Del-City.
Would similar V-crimped lugs be adequate for the new 1/0 cables? Or do they add too much resistance at high loads? The old cables do seem to have more voltage drop than I predicted based solely on the cable length and size.
Alternative lugs might be the Fusion solder lugs. Not cheap, but I only need 4 and still cheaper than a $200-300 crimping tool.
And then I hear of people using thick walled copper pipe? And solder?
I would rather cut and lug the cables myself as I'm not exactly sure of their routing.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,273 PostsLatest Activity: Jun 24, 2025
