ktmrfs
Oct 29, 2013Explorer III
If it's easy, go with #4 welding cable easy to get, reasonably priced, and run the negative to the frame rather than a long run to the battery.
And if I remember correctly, #4 is the biggest dia wire you can get into the PD lugs.
#6 of that length will limit the current somewhat, and likely have it drop out of constant current a bit early. However if it is difficult to change, I'd at least start with the #6 and see what happens. I think you'll still see way better results than the WFCO.
How much it affects charging is noticeably dependent on what kind and how many batteries you have. Based on my previous experiece with wire size and PD converter, the #6 will likely get you in the 50A range, and #4 closer to the full 55A range if the batteries are discharged enough.
If you were looking at the 60A or 80A unit, another story, then you would need to upgrade the wiring.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
