RJsfishin
Oct 30, 2013Explorer
Its not worth changing wire. If you loose anything, it will be for only the first 5 or 10 minutes while the converter is putting out max current. After several minutes, the current will taper, and will then be well w/ in the current range of 6 ga wire. I ran a PD9155 on 6 ga for many years.
Just make sure you get the optional remote Pendant control w/ it.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
