DryCamper11
Oct 30, 2013Explorer
otrfun wrote:
too small gauge of cable (for the run length) and may limit the PD4655's charge current when it's in the 14.4 volt bulk mode.
True? False?
True. You can't get cables that are too thick. There's always a compromise. I chose 1/0 welding cable (buy from the local welding store) for the reasons set forth above, but think about your needs. If you don't need maximum rate charging at the end, because you normally are plugged in or have solar, your cables may be fine.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
