BurbMan
Feb 23, 2015Explorer III
I would get a roll of Liquid Tight flexible conduit and use that for everything. It's easy to work with and will give plenty of protection for the wires. I believe if you use a pull elbow like you linked to, you can insert the Liquid Tight conduit into the fitting and glue it with PVC cement just like you would with rigid Sch 80 conduit. Get rid of that blue fitting and use another like you have on the bottom of the box in the picture. For one #6 1/2" conduit should be OK, for 2 I would use 3/4". If you have the controller surface mounted, I would run the conduit right up to the controller, not just stop it at the floor....may as well protect the wires for the full run. I think 3/4" conduit needs a 1" hole IIRC....is this the info you were looking for?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
