jrnymn7
Mar 02, 2015Explorer
First off, that 160w portable's Isc is a little high for that 10a controller. Should be 8a, max. And usually, Imp is lower, not higher, than Isc.
10a thru 20' of 12ga will have a v.d. of ~ 5.5%... too much.
10a thru 30' of 10ga will have a v.d. of ~ 5%... too much.
10a thru 40' of 8ga will have a v.d. of ~ 4.3%... still a little too much.
Bump everything up two sizes, and you'll be good; thus allowing for additional losses at circuit breaker and connections, as well as temp compensated charging.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
