NinerBikes
Mar 03, 2015Explorer
Bend wrote:
OP-
The secret of good solar PWM charging performance is conserving voltage. Once that is done, amps will take care of themselves. You need at least 16.5 volts at the controller for it to work and usually 14.8 volts at the batts. Your winter RV will probably need more solar watts and battery voltage due to low temps.
This, and sometimes you need even more at the battery with problematic batteries like group 31's or Trojan T-1275's, something aroud 15.0 to 15.3V at the batteries. See the "My screwy 31" thread by landyacht318.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
