- myredracerExplorer IIYou might want to install a grounding block at the coax entry on side of the RV and make sure the block is "solidly" connected to ground. The ground wire & connection in an RV and the same in a CG pedestal may not be in good condition and unable to adequately dissipate the energy to ground. If really concerned, maybe a driven ground rod is thing to do if at a permanent site. Most pedestals don't have a ground rod and rely on a ground wire back to the source panel. CG wiring is not always in the best of shape.
If you have a hard-wired PI EMS, I found that the ground wire they come with is really small gauge. I reconnected it so that the ground wire from the panel runs through the EMS with same size gauge all the way to the power inlet. I've seen a couple reports of some having their EMS go up in smoke after a lightning strike which could be because of the way the EMS comes.
Satellite dishes, antennas and incoming coax from the street in houses have to be grounded by code and they don't use surge suppressors. - Sam_SpadeExplorer
GordonThree wrote:
It's RF energy, volts and joules don't really apply.
The thing you are trying to protect AGAINST is NOT RF.....but high voltage hits caused by lightening or crossed wires somewhere down the road. - 2oldmanExplorer II
GordonThree wrote:
Well, they sure will apply if lighting comes anywhere close!
It's RF energy, volts and joules don't really apply. - Retired_JSOExplorer IITV’s Are cheap, I’d worry more about trailer electronics getting fried. A/c and fridge circuit boards and converter etc. invest in a good surge protector and hope for the best.
- Big_steveExplorer
ItsyRV wrote:
Big_steve wrote:
Do most folks use an in-line surge protector on their cable tv coax cable? If so, where are you connecting it to ground?
I made mine using a standard coax cable in-line surge protector. It hooks up to the campground's cable connection using the attached 6" coax cable with a standard coax cable hooking to the other end. I had attached a short 18" bonding cable with an alligator clip to the ground screw. The alligator clip just attaches to the electric or water ground clamp at your spot.
The coax cable surge protector (not to be mistaken for a ordinary grounding connector) was about $25 and the bonding cable was $5 from a welder who didn't need it.
Thanks. - GordonThreeExplorer
2oldman wrote:
DFord wrote:
Well, perhaps I don't know how to read the specs on those things, but I was expecting the words 'volts' and 'joules' somewhere, but found none.
Take your pick (lots to choose from):
It's RF energy, volts and joules don't really apply. - ItsyRVExplorer
The coax cable surge protector (not to be mistaken for a ordinary grounding connector) was about $25 and the bonding cable was $5 from a welder who didn't need it. - 2oldmanExplorer II
And I couldn't find a single review where anyone said they were actually struck by a surge or lightning. - DFordExplorerTake your pick (lots to choose from):
https://www.amazon.com/s?k=tv+cable+lightning+arrestor&crid=3V49SJN73VU33&sprefix=TV+cable+light%2Caps%2C511&ref=nb_sb_ss_i_1_14 - GdetrailerExplorer III
Big_steve wrote:
road-runner wrote:
2oldman wrote:
Lightning, I would think.
First I've heard of this. Where would a surge of power come from in a coax cable?
Yes, Have lost a tv and and a desktop over the years from nearby lightning coming in the coax cable.
NOTHING short of fully 100% disconnecting the cable from a TV, cable modem, TV antenna is going to "protect" you from an direct OR INDIRECT lightning strike on said device.
Anyone who tells you that their addon device will protect your device from a lightning strike is full of baloney.
I have never lost a TV or any other device due to lightning strikes when they are fully 100% disconnected.
I have lost POTS phones, DSL modem, answering machine, router, PC network card, network hub which was not disconnected and we had a nearby lightning strike (not direct hit).
So, as a rule of thumb, IF there is a 30% or better chance of an electrical storm and we are not going to be home, EVERYTHING from DSL modem, PCs, TVS, stereos, Sat equipment MUST be disconnected. The only item that does not get disconnected is the POTS phone and answering machine.
You simply cannot buy a $10-$1000 addon wonder device which can handle the power of a lightning strike.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
