Have a cable problem , when I hook up to rv park cable, I get a snowey picture , have checked all connections they are tight, also power booster turned off. Any ideas
The wire inside or at the external connection is bad. You will have to replace every connection to solve the problem. I strongly recommend using the compression type F connectors. It is what all of the professionals use. You do need a special tool to install them.
