Have a cable problem , when I hook up to rv park cable, I get a snowey picture , have checked all connections they are tight, also power booster turned off. Any ideas
So, are you saying that running a cable from the campground post to the TV gives you a good signal but running it through the RV (and possible splitter/splitters) does not give you a good signal? If so, you already have the answer to your question.
