Have a cable problem , when I hook up to rv park cable, I get a snowey picture , have checked all connections they are tight, also power booster turned off. Any ideas
One thing you might try if you have some co-ax with you is run the co-ax directly from the CG outlet to the back of the TV. If it works, then you've got a connection problem somewhere or faulty coax/amp. plate.
A snowy picture would suggest an analog signal whereas a pixelated picture would suggest digital. Is anyone else getting an analog or digital signal?
