Busdriver's avatar
Busdriver
Explorer II
Jul 13, 2018
Cable tv
Have a cable problem , when I hook up to rv park cable, I get a snowey picture , have checked all connections they are tight, also power booster turned off. Any ideas
  • I am thinking that the cables are miss marked or on some rigs you must move a cable from satellite input to cable input behind the TV.
  • enblethen wrote:
    You could also route a cable from the campground connection directly to the TV to see if signal is good.
    have done that signal is good
  • You could also route a cable from the campground connection directly to the TV to see if signal is good.
  • Might be that is all the better the campground system works. Ask neighbors about their picture before doing much work to your things. Yes, I have seen all kinds of issues in campgrounds.
  • Verify that the cables is what you think it is.
    Check continuity as it could be miss marked.
  • siggyd777 wrote:
    Did you do a scan for CABLE channels on your TV?
    Siggy
    yes like said snowey picture
  • Badly crimped cable end, cable insulation striped by pulling through a small opening, too many splitters, BOMB connectors need cleaning.
    I keep a small wire brush in the compartment with the cable and clean the park connector when I plug in.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
