1L243 wrote:
I will forget the idea of electric heat but would like to be able to power Tv's, Satellite, USB charger, Furnace if needed and a coffee maker once a day plus a small microwave for 10 minutes a day.
I will research a 1500 to 2000 watt pure sine inverter with smart charger and built in transfer switch.
This one is a bit small (1200 watts), but it still does everything you want, without the generator start function.
Samlex EVO-1212F-HW Pure Sine Inverter/Charger - $744 Amazon1L243 wrote:
Is a all in one inverter the way to go or would going with separate units be more practical for purpose of replacement and cost?
For ease of installation and operation an "all in one" is the way to go. I would not be concerned about replacement if you buy a good quality unit.
Standalone units from less common companies
(Chinese) are much cheaper
Reliable 2000W Pure Sine Wave Inverter - $309 Amazon.
(Yes, this is direct from China, but is gotten a lot of good reviews on YouTube.)No automatic transfer switch and you have to rely on your solar and converter to charge the batteries. An automatic transfer switch could be added
but the wiring is non-trivial.
