wannabegone
Jun 20, 2016Explorer
Calling Solar Gurus
It's time to pull the trigger and install solar on our 1181. I'm planning to order within the next month to be ready for a trip near the end of summer. The TC is pre wired for solar. I've decided to wire in series, use a mppt controler and use the existing pre wiring. Here is my list, what more do I need.
Blue Sky Energy's Solar Boost 3000i solar charge controller
2 RENOGY 100 Watt 100w Polycrystalline Photovoltaic PV Solar Panel.
RENOGY Two Pair of 10ft. Adaptor Kit Solar Cable PV with Mc4 Female and Male Connectors AWG 10
2 Sets of Renogy Solar Panel Mounting Z Bracket Set of 4
CES 2 Pin Quick Disconnect Wire Harness SAE Connector Bullet Lead Cable (10 AWG)
1 ATC/ATO Water-resistant Fuse Holder - 10 AWG
Other than decor and time what else needs to be added
