Gdetrailer wrote:
Takes a lot of solar, battery AND MONEY to make the system you long for, way above your budget.
Why does everyone keep saying this !Victron SmartSolar MPPT 100/50 Charge Controller - $325 AmazonVictron SmartShunt Battery Monitor - $130 AmazonSamlex EVO-1212F-HW Pure Sine Inverter/Charger - $745 AmazonThat is $1200 ! If you shop hard, you should be able to find 200W polycrystalline solar panels for under $200 each.
($150 a piece would be a very good deal at 75ยข/watt, but do-able) Add mounting hardware and some wiring and yes, you will probably be up around $1700
(If I was building this for myself, I would want 600W of solar and a 2000W inverter and I would use a 24V battery bank but that would be over $2000.)
