1L243 wrote:
Am I to assume that the concerns with the WFCO 8900 converter charging or not charging the batteries correctly only a issue when I am plugged into shore power and nothing to do with Solar correct?
When charging the batteries on Solar through the Solar charger/controller with built in safe guards there should be no issue correct?
PS I purchased the Renogy 2000w Pure Sine Wave Inverter
Solar has nada to do with a converter. They do play well together in my case, and may do the same for you.
Since you have your inverter--forget what I said about an inverter/charger.
